Incorrect audio showing on videos
I just got infuse 6 and love the new update but there is one thing that is slightly annoying. When showing what audio format the video has, instead of showing TrueHD or Dolby Digital Plus it shows “MPEG-4 Audio Lossless Coding (ALS)” and “RealAudio SIPR / ACELP.NET”. I know it’s really nothing but the old way was neater. I’m also thinking this might be a bug because I do have one show that shows Dolby Digital Plus correctly and one that shows TrueHD 7.1 correctly. Only these Dolby formats are effected, everything else is normal. Very weird.
Check and see if you have 6.0.1
Check out the third item on the 6.0.1 update. That may solve your issue.
Thanks this fixed it!
You’re welcome!
