GeremY
August 16, 2023, 5:46pm
1
It is difficult to see, but colors are inaccurate in H264/H265 10 bit files (also without HDR).
In the first picture you can see Infuse (on the left) has a slightly different tone than Movist (center) and Quicktime (right). Both Movist and Quicktime reproduce the image accurately.
In this second picture you can see the same issue, with Infuse erroneously dimming the blacks.
I understand that it’s difficult to see but nevertheless Infuse is a little bit inaccurate.
Test files:
jellyfish-10-mbps-hd-hevc.mkv - Google Drive
Dune - Official Trailer 1 (6ch).mp4 - Google Drive
Device: MacBook Air M1
james
August 16, 2023, 6:11pm
2
The Infuse HDR color palette has a bit of a lighter bias, whereas QT is a bit darker. If you prefer one over the other, you can switch between them in Infuse > Settings > Playback.
GeremY
August 16, 2023, 6:27pm
3
james:
All kidding aside, the Infuse HDR color palette has a bit of a lighter bias, whereas QT is a bit darker. If you prefer one over the other, you can switch between them in Infuse > Settings > Playback.
Lighter? To me it seems that Infuse is a bit darker than Quicktime/Movist/Optimus. And I’m already using Apple HDR color palette (but the video are not in HDR, so I don’t know if this matters).
Another example:
@GeremY check this post here, the Apple Palette can only reproduce accurate color when in “HDR video” mode. Not really sure a bug of Mac or Infuse
@james
I just toggled between “P3-1600 nits” and “HDR video (P3-ST 2084)” display mode on my Macbook M1pro to see if it makes any difference.
To my surprise, Apple color pallet in “HDR video (P3-ST 2084)” mode is actually accurate and identical to Quicktime!
Additionally, “Infuse color pallet” also produce different results in “HDR video (P3-ST 2084)” and “P3-1600 nits”. It’s especially noticeable in dark scene.
So it looks like Infuse actually has bug that affect both Infuse & Apple color p…
GeremY
August 17, 2023, 7:18pm
5
Unfortunately I have no such option on my MacBook Air.
However I found this thread that can perhaps be helpful to developers for implementing a better Apple color palette:
opened 12:58PM - 17 Mar 17 UTC
closed 06:19PM - 07 Aug 23 UTC
core:color-management
### mpv version and platform
macOS 10.12.3, mpv 0.24.0, pre-built by stolenda… ta
### Reproduction steps
Open the attached sample video in mpv and QuickTime Player.
### Expected behavior
The colour in mpv looks the same as in QuickTime Player.
### Actual behavior
The colour in mpv is dimmed compared to QuickTime Player.
#### QuickTime Player (good)
<img width="1440" alt="quicktime player" src="https://cloud.githubusercontent.com/assets/2100868/24068914/bd1d6cea-0b57-11e7-8eb9-72a5d39cd549.png">
#### mpv (dimmed)
<img width="1440" alt="mpv" src="https://cloud.githubusercontent.com/assets/2100868/24068915/c1a49176-0b57-11e7-9ce2-bee841316ce8.png">
### Log file
http://sprunge.us/EQOa
### Sample files
#### Config
player-operation-mode=pseudo-gui
icc-profile="/Library/ColorSync/Profiles/Displays/Color LCD-F466F621-B5FA-04A0-0800-CFA6C258DECD.icc"
hwdec=auto
log-file=/Users/fumoboy007/Desktop/output.txt
#### Sample Video
https://www.dropbox.com/s/khnzs60z1wz2fjt/Rec%20709%20Sample.mp4?dl=1
The video is tagged with the colour profile that Finder describes as `HD (1-1-1)` (Rec 709).
