Hi there! First time posting on the forums.
I’m reaching out because I’ve been troubleshooting persistent and frustrating audio sync issues on my Apple TV 4K (3rd Gen) setup for several weeks, specifically when using Infuse.
My setup involves a TCL 50C803 TV connected via eARC to a Samsung HW-Q800D soundbar. I have content matching (both dynamic range and frame rate) enabled on my Apple TV, which seems to be a key factor. The audio/video synchronization is inconsistent and varies depending on the specific file’s dynamic range or frame rate, likely triggered by the TV switching input modes.
To confirm the source of the problem, I’ve tested the same video files using Infuse on macOS and iOS devices. In those cases, the audio sync is perfect. This leads me to strongly suspect that the issue lies with the interaction between my TCL TV’s eARC implementation and the signal switching caused by content matching, rather than Infuse itself.
Given that a universal fix for this TV/eARC behavior seems elusive, I’ve come to rely heavily on Infuse’s built-in manual audio sync functionality. I really appreciate the inclusion of this feature as without it, I would unfortunately be unable to use Infuse at all. The “tuning mode” within the manual sync is particularly helpful and a genius addition that makes finding the right delay much easier.
However, because my audio sync issues are inconsistent and depend on the content’s format (requiring frequent adjustments), I find that the current workflow for using the manual audio sync, while functional, could be significantly streamlined for users like myself.
Currently, adjusting the audio sync requires:
- Opening the full-screen audio delay menu, pausing video playback.
- Navigating within the menu to enable tuning mode.
- Adjusting the sync, which in tuning mode is in 50ms increments.
- If finer adjustment is needed, exiting tuning mode and using the 10ms precision setting within the menu, which necessitates repeatedly switching back and forth between the menu and playback to check the sync.
My core suggestion is to enhance the usability and speed of the manual audio sync feature, specifically by making the tuning mode more accessible and precise.
Here’s a proposed flow:
- Allow quicker access to initiate a “tuning mode” directly during playback (perhaps via a long press on an existing button, or a dedicated shortcut if feasible).
- This “quick tuning mode” would ideally operate as an overlay during playback, without requiring a full-screen menu that pauses the video.
- Adjustments within this quick tuning mode could ideally offer finer precision, perhaps in 25ms increments initially, with the option to switch to 10ms for final fine-tuning.
- A simple action, like pressing the back button or a designated “done” button, would then exit tuning mode and save the adjusted sync value for that content.
I understand that users facing intermittent, source/hardware-dependent AV sync issues requiring frequent manual adjustment might be a specific group. However, I believe that improving the manual audio sync workflow in this manner would be a convenient and valuable enhancement for anyone who needs to use this feature, making Infuse even more adaptable to challenging playback environments.
Thank you for considering this suggestion and for developing such a fantastic video player.
