Option to disable title card between episodes. That is, the black screen with the episode title that automatically shows up. Example here. Even though it’s brief, I would prefer the option to hide it.
Play next episode prompt. After the episode ends, display a screen with a countdown and option to start the next episode (similar to Plex or Netflix). You could also add a preference to decide what happens after the countdown if the user doesn’t select anything (either continue with the next episode or stop playback). Bonus: integrate this with the upcoming Plex feature where it will detect credits (similar to intros), and show this countdown while the credits roll.
I believe this is already there but requires a tap to show timeline first.
