Improve playlist ordering
Setting up a friend’s device (iPad) and I found it nearly impossible to recreate a playlist of ~100 items without going one by one. I tried adding them all at once and infuse didn’t keep the original sort order from “All Movies” where I sourced them. They seem to be added randomly. Then I tried reordering in grid and list view. Both were very challenging.
Improvements:
  1. Keep order from original place you added the items
  2. Allow sorting of the entire playlist by Title, Filename, Date, etc. Do like iTunes where you copy to play order after sorting.
  3. Bigger spacing in grid view so you don’t accidentally swap something if you just want to move the grid
  4. more icons (smaller icons, rows and cols) would prevent so much scrolling
  5. Speed up grid view
  6. List view sorting is really slow and it is easy to accidentally play the item instead of swapping
  7. Bonus: smoother animations when trying to go far. It keeps snapping to rows and that slows it down.
  8. Bonus 2: Share a playlist with a friend
  9. Bug: Sometimes playlist editing doesn’t stick and it will add back items I’ve deleted or put them back to previous position.
