Improve audio/subs list UI
I have ripped a lot of my BluRays using MakeMKV. I’m trying to play Despicable Me 3 on Apple TV 4K on iOS 11.2 beta 3 using Infuse 5.6. Infuse handles the information in the audio and subs menu differently from other players. It should show it like
[Lang] [Codec] [Channels]
English - DTS-HD MA 7.1
English - TrueHD 7.1
English - DTS 5.1
English - Dolby Digital Plus 7.1 (E-AC-3)
English - Dolby Digital 5.1 (AC-3)
etc.
Infuse puts Track/Number # in front of audio and subtitles. Is it possible to fix this so the UI will look more clean?
I have posted some screenshots from other players, so you can see what I mean.
Some more screenshots from Plex on Apple TV. Is it something that you will take a look at in the upcoming versions?
It looks like this might just a translation change, so I think just dropping the Track # (Nummer #) text would help.
Something like this would be better, no?
1 - English, DTS-HD MA
2 - French, Dolby
Yes but also with channels. Does it need a number ?
English - Dolby TrueHD 7.1
English - DTS 5.1
English - Dolby Digital 2.0
[LANG] - [CODEC] [CHANNELS]
The same with subtitles, just a list of text
OFF
English
English (forced)
French
German
Danish
Swedish
Good idea, we’ll see what we can do.
any updates regarding this?
Additionally, it would be nice to be able to change the audio out source from the player menu. In Plex I can choose to send audio out through the Apple TV or another hookup without needing to pause the item being watched. I was expecting this ability the first time I used Infuse and went to the “Audio” tab.
I thought 5.7.3 was supposed to improve handling of audio/subtitle track languages tags and fix this UI problem. The UI is still the same :confused:
It did fix the tag. The UI issue you previously described is different. The tag issue was about using the proper audio track/subtitle. For example, in another thread someone said Infuse would default to a commentary audio track rather than the default track. That’s what was fixed.
I’ll add here the info I posted in another thread:
This is what I get from MediaInfo, using as source the original movie of this thread:
Audio #1
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Duration : 1 h 52 min
Bit rate mode : Variable
Bit rate : 3 212 kb/s
Maximum bit rate : 5 394 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Delay relative to video : 8 ms
Stream size : 2.52 GiB (17%)
Title : Venom.2018.2160p.BluRay.x265.10bit.HDR.DTS-HD.MA.TrueHD.7.1.Atmos
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Since in the audio menu I get this format "[Title] (TrueHD [Channel(s)], [Language]) where [Title], [Channel(s)] and [Language] are like the ones above, I suppose that you could just ignore [Title]?
To me the best format would be:
“[Codec] [Channel], [Language]” - ex: “TrueHD 7,1, English”
