Hi, I was wondering now that I use ATV XBMC edition how I can access the 160gb hard drive by FTP. I can’t seem to connect by just using the IP address (local 10.0.0.xx) I have an ethernet connection and I can access my iMac from the ATV to stream movies, however, I want to copy movies onto the drive.
I have cyberduck 2 and tried to AppleTV method described in the knowledge base that I used to use but this no longer works. (i.e. using AppleTV.local etc). Is there a method I can use to copy the files directly to the hard drive by FTP or something similar over ethernet?
Is there a Gotham/XBMC password I’m missing to access locally? Thanks.
