ifaith will not save my <apticket>
Hi i have a apple Tv 2 Gen on 4.4.4 when i  use ifaith to download my blogs the apticket just has 000000,
i have jailbroken 6 apple Tv’s on  4.4.4 using the info on the site “THANKS”
but i know if i try to Jailbraking  using the blobs i will get 1600 and will be forced to go to 5.0
No matter how many times i run ifaith the apticket is always 00000
has any one got any advice on how to make ifaith read my apticket?
Try using redsn0w to back up the blobs (it is under the Extras button) and then use TinyUmbrella to fetch them from Cydia.
Thanks Matty
i am using Redsn0w 0.9.10b6 and keep getting unexpected error after i put it in dfu.
at the bottom it is saying  “connected  unknown device (DFU mode)”
am i using the right Redsnow ?
Are you using a Windows or a Mac computer?
Windows
