If I power off Apple TV 2G, do I have to jailbreak it again and install ATV FLASH?
Guys, I am moving to new house and will need to remove apple tv 2g from power plug. Do I need to jailbreak it again if I poewr it off? Thanks in advance for your help/suggestions.
No, you will not need to jailbreak it again. However, if you are using a tethered jailbreak, you will need to connect it to your computer to boot it up when you plug it back in.
see whats weird with mine is everytime i unplug the main power then move it to a different room, after i plug it in, i see the apple logog and it is no longer jailbroken!  why what is it?
It sounds like you may be running an older 'tethered' jailbreak.
If you re-jailbreak with the current version of Seas0nPass you can upgrade to an untethered jailbreak.
http://support.firecore.com/entries/387605
[quote="james"]
[/quote]
sorry i have tried more than once and still no go!
Which version of Seas0nPass are you using?
