If I have match content turned on, should I set to 4k SDR or 4k HDR?
I have a 4k HDR10 capable t.v.
If I keep the ATV4K setting to 4K HDR (with match content turned on), will Infuse try to map SDR to HDR?
If that’s the case, should I keep my ATV4K setting to 4k SDR as mentioned here: Reddit - The heart of the internet
With the Match Content options enabled, Infuse will adjust the video output to match the video being played.
So, if you are playing an SDR video, then the Apple TV output will be changed to SDR.
The default setting you choose, really only affects the menus…so pick the one that looks best to you. :slight_smile:
