iCloud syncing vs trakt syncing
Hello,
After upgrading to infuse 6 i decided to migrate to iCloud syncing. After a bit of a rough start (for some reason everything was shown as not watched and I had to manually “re-watch” everything) I thought I finally got things under control.
However I noticed that with iCloud sync if I watch something and then change the file name, it would show up as not watched. With trakt, the file would remain watched even after renaming. Is this a bug?
Keep up the good work,
Thanks!
Bumping this just in case someone has had a similar problem.
Thanks!
