I tried deleting iCloud Infuse backup several times.
I tried creating the initial Infuse settings on either iPad or Apple TV.
Nothing works.
It’s like the devices are talking to different iCloud backups. (LOCAL library is missing on iPhone X fresh install).
I’d be happy to just use trakt, but I can’t find it on iOS.
Thanks James, I just found the trakt icon actually (after waiting for the forum post approval). A little bit tricky to find if you don’t know their icon.
Anyways, it works well enough now.
Still a problem with iCloud sync, so I will leave this thread open.
I read that thread many times, and have everything enabled (see pictures in original post).
Regarding ‘Saved Favorites and Lists (folders and Library categories)’:
This does not happen when I reinstall Infuse app on iPhone X for example (it is missing LOCAL). See last picture.
When I open the app it is blank, then syncs with iCloud, then adds only JOTTA (not LOCAL).
It’s like it is talking to an old/different sync entirely.
I only have 1 iCloud account.
