Hulu on ATV2
Like a lot of people on this forum, I am looking for Hulu.
I am on the latest ATV2 software - well, it tells me I am when I select upgrade software.
So far, I do not see the new Hulu functionality.  I guess it would be located under “Internet” menu?
I’ve turned it off…turned it on…asked to check versions… anything else?
You need to have XBMC loaded and then load the bluecop repository that has Hulu. Here’s a good post to get you started. Despite what the article says - follow it to the letter and Hulu works - works great for me!
You will need to JB your aTV2 though and highly recommend the most current aTV Flash black.
Thanks Easlepad.  I believe it’s “native” on ATV now… at least according to their press release and website.  I believe it’s supposed to show up as an option under “Internet” as “Hulu Plus”.
On the Apple website: Apple TV 4K - Apple
Netflix, Hulu Plus, YouTube, Vimeo, MLB, NBA, NHL, and more.
Play movies and TV shows from Netflix and Hulu Plus, browse videos from YouTube and Vimeo, and see live MLB, NBA, and NHL games, scores, stats, and more.
Thanks though.
http://forum.firecore.com/topic/8665
