hey,
what’s the procedure for upgrading from 3.2 to 3.2.2 & beyond?
can i just re-patch the newer version over the old version, without a factory restore now?
is v3.2.2 solid? should i?
Once you have version 3.2 installed, all future updates can be installed on top of it. The installer removes any old plugins, and installs the updated versions.
No factory restore required ![]()
