how do I upgrade 3.0 and 2.02, what is the correct sequence?
thanks in advance
If you checked the box to disable automatic updates, then create the new patch without the “Disable Update” checked. Patch the AppleTV with the new patch, update the AppleTV to the newest version, and then re-patch with the newest patch. That is the best way if you want to keep your content on the box and not do an AppleTV Restore.
thanks worked perfectly
