When I used Infuse Pro 5 on my iPhone 6s, some videos’ voice couldn’t catch up with their pictures. However these videos could play properly on my MacBook using IINA. I consider maybe soft decoding could solve this problem, but I couldn’t find the switch button for the decoding method choice.
Infuse doesn’t have a switch for this, as it will always use the best option available.
If you’re having trouble with a particular file, it might be best to send in a sample which we can review here.
Samples can be submitted here.
