How to setup XBMC for local network streaming
OK, I use to be able to do this but after upgrades from ATV, XBMC and my Mac, I can’t figure it out. And I did try :roll:
Here is my setup: I have a LaCie Drive, name “LaCie” mounted on my iMac. I am trying to access this Drive. How and where do I set the settings in XBMC so I can stream the movies located on this Drive?
The local network address for my iMac goes like this:
IP: 192.168.1.106
Local network name: john-doe-computer.local
or
afp://192.168.1.106 (which if I use this address from my laptop, do give me access to mount whatever volumes I have connected to this IP)
or
John Doe’s Computer
Drive holding my movies would be address as:
LaCie/Movies
On the iMac, the system preference allows for files sharing.
Can someone put me in the right direction?
Many thanks.
–Luc
If you setup a network share through nitoTV all applications can utilize the networked media. No need to setup separate shares in XBMC, Boxee etc.
http://wiki.atvflash.com/index.php?title=Network_Streaming
Great Help! Took a big 5 minutes. Many thanks :smiley:
