how to setup the Couch Surfer default homepage?(not the autostart when power on))
hi everyone,if anyway to setup the Couch Surfer default page to view,such as on enter menuitem “enter address” can be a default url as"www.google.com"
thanks
i means not the “Improved Couch Surfer with Auto-Start”
when enter the Couch Surfer can load a page,but not always power on the appletv
For now, the only option would be to create a new bookmark, then select this bookmark from the Bookmarks menu.
To add a bookmark:
  1. Navigate to the page you wish to bookmark
  2. Press menu to bring up the popup menu
  3. Select the add bookmark option.
thank you!!
