Under my favorites list is a section called Top Rated Movies that I would like to remove. Unfortunately I can’t find it. In the library there is a Movies - By Rating which I can add and remove but this is not the same thing apparently. Where is the toggle for this list?
This is one that’s a example of how versatile Infuse is try Library>Movies>By Rating>Top 30 Long press on “Top 30”
