Is it possible to reduce the size of the metadata? I’m approaching 6 Go with my current library, which is a lot considering that the content are only images and text… and that my storage is full on my iPad 16 Go (with iOS and system using 9 Go).
What version of Infuse are you using?
Infuse Pro 7.1.2
We’re investigating a few reports of this, and hope to have more news soon.
Today’s 7.1.3 update includes a number of optimizations aimed at reducing the cache size.
After installing the update, Infuse will work to optimize the images on your device, so you should see the cache size start to decrease over time as you use the app.
