How to quit XBMC and go back to ATV?
I have the latest version of ATV (3.5.3) with the included XBMC/boxee…
How can I quit XBMC (not shutdown) to go back to ATV normal operation…
Now I only can Shutdown… so If I have to use other apps I have to wake up (I have my ATV at bedroom) unplug the power cable, replug to restart the ATV…
thanks!
It’s possible you may just not see the quit icon on the screen. XBMC has the same problem on some TVs as Boxee does, it stretches further than the TV will show you. Follow the same steps found here and let me know if that helps.
http://forum.atvflash.com/viewtopic.php?f=20&t=1357
