is this name format correct ? Youre.Next.2011.mkv? or you.’re.next.2011.mkv?
please help
please help
Is this title listed on TMDB?
I found this one, but the release year is listed as 2013.
yeah that is the one. please advise how to name my video file ?
Either one of the formats you showed above should be fine as long as you correct the year so either Youre.Next.2013.mkv or you.’re.next.2013.mkv should work.
I personally make it a point to avoid any special characters like the apostrophe just to be on the safe side even though it’s not one of the illegal characters but that’s just what I’ve gotten used to over the years and it seems to keep things working better for me.
thanks. !!!
