Just found out about the smart tags feature as I need to have 1080p versions for streaming upstairs as c.f. 4K for main TV.
So I have a 1080p version of an existing 4K film (all films are in one big “movies” folder, not within individual folders):
Big Hero 6 [2014] 2160p 5.1.mkv
Big Hero 6 [2014] 1080p.mov
^^^This shows up as 2 separate entries, both pointing to the correct film but showing as 2 separate covers.
How do I get them to show as 1 cover which gives the option of 2 resolutions when clicked? The 101 metadata page shows plenty of inbuilt tags but they refer to editions, mine are the same film but different resolutions.
Do I label them as:
Big Hero 6 [2014] {2160p 5.1}
Big Hero 6 [2014] {1080p 2.0}
or do I use:
Big Hero 6 [2014] {edition-2160p 5.1}
Big Hero 6 [2014] {edition-1080p 2.0}
or is there another way I should be naming them?
If I do name them differently, how do I name the custom covers? They have to be the same as the parent movie file so do I need 2 covers now?
Or do I just keep 1 cover and, in the case of my last example, do I name the cover:
Big Hero 6 [2014] OR
Big Hero 6 [2014] {edition-2160p 5.1} OR
Sorry for the Q’s but the 101 page doesn’t explain it very well.
If you want to have them tagged based on resolution only, Infuse will do this automatically without you having to add any special tags to the filename. Custom tags can be used to specify other things, such as edition, cut, part 1, part 2, etc…
Smart groups and tags are only available when using the Library, so items will not be grouped when browsing directly via folders.
So if I remove the tags and go back to the original filenames I was using:
Library mode should group them correctly? If so, I’m happy to switch to Library mode .
However, this leaves me with the covers issue, will I now need a cover for each instance of the film, e.g. like this:
(easy to do as I only need multiple resolutions for the films my daughter watches, so it’s not a lot of duplicates)
If you have metadata fetching enabled, Infuse will fetch covers automatically. If you want to add your own covers Infuse will use the cover from the first item for the smart group, which would be the highest resolution version.
If you are using your own fanart, those are all displayed depending on the version which is highlighted on the details page, so you would want to add fanart for each version.
You can also set the version which is selected by default when opening the details page. This can be adjusted by changing the ‘Select Version’ option found in Infuse > Setting > Collections & Groups. The default setting of ‘Auto’ will attempt to choose the format which is best for the device, but you can force this to choose either the highest or lowest resolution.
