I had a manual extra I added for a TV show season in Plex. I deleted it from my Plex library, emptied trash, removed bundles, optimized database, etc. Please doesn’t show the extra anymore. Infuse still does. Even after scan for new changes, refresh metadata, force quit then re-open app, etc. The deleted extra is still there.
How can I force Infuse to not show it?
This issue is indeed very frustrating. Have you tried clearing all cache and rescanning metadata?
Something must be wrong with Infuse @james
I actually figured it out and it is PLEX that has something wrong. The extra wasn’t showing on the web UI because apparently they never show on web UI, I had to double check in the Plex iOS app, which was still showing the extra. So deleting the file didn’t remove the extra from Plex, even after rescanning plex library, refresh metadata, remove trash, etc. So Infuse was just showing what it was receiving from Plex, which is what we want.
I had to fully remove the series from Plex and re-add it to get the extra to disappear from Plex (iOS). It was then gone from Infuse as well. The old school “plex dance.”
So it was a Plex issue, not Infuse. Plex’s handling of in-line TV extras seems really half baked.
