[How-To] Fix New PwnageTool/Sn0wbreeze 4.3.1 Untethered JB
To fix the installition packes from ATV-Flash here is what you need to do
you will need to ssh into the AppleTV which will be preinstalled in the JB
Mac:
Open Terminal
ssh <ip address of AppleTV>
Login as Root
Password: alpine
Windows users download Putty for SSH
[code]http://the.earth.li/~sgtatham/putty/latest/x86/putty.exe[/code]
next once you login you will need to type or copy and paste the following commands
sauriks package is missing add it with:
> echo "deb http://apt.saurik.com/ tangelo-3.7 main">/etc/apt/sources.list.d/saurik.list
Then update commad with:
> apt-get update
and the install the missing dependencies with:
> apt-get -f install
then you can install all packages from ATV - Flash
Enjoy :D
Hey, thanks a lot for this. I haven't had a chance to try it out yet, but it's good to know what to do ahead of time. =)
it’s a little bit confusing. like many other users (for example in the comments @ the sn0wbreeze news on appletvhacks.net), i’m stucking at the point, that the jb doesn’t work (itunes error 1600). so far, without the jb i can’t ssh to the device. what’s the matter of that itunes errors?
Usually, error 1600 is caused because you did not put your ATV2 in DFU mode. Let Pwnage tool guides you through the process...
it doesn’t make sense. actually i’ve tried it with iREB (black screen dfu) and the result is error 14. don’t know what to do :frowning:
