Are there suggested tools or methods for editing/adding metadata to home movies that Infuse will utilize as embedded metadata or local metadata?
Just me personally but I’d never use embedded metadata with Infuse. That does slow down the scanning process when you have that enabled. I’d suggest just adding a xml or nfo file and take it from there.
Thanks for the reply, is there a reference that I can review for creating the xml file containing the metadata in a format that infuse can use?
Yup, there’s one in the users guide I linked to above under samples.
