How to downgrade media player?
The latest media player is v buggy, but the last version worked fine for me. How do I downgrade to the previous version? Will raise bug reports when I have a working media player again.
Unfortunately you can’t downgrade, but if you submit a bug report we’ll work to fix any issues you’re running into.
