How to disable infuse to look inside sub directories?
Infuse will look inside sub directories, if the sub dir contains only one video file, it will hide the dir, and display the file on current level.
This feature sounds good, but actually bad.
My directory name is readable, but the filename inside it is not.
So this feature caused me can not find out the video I want.
