Is there a way to prevent my atv2 from auto updating ? I do not see the feature in the apple tv 2 settings.
Thanks in advance.
Thanks in advance.
Someone can chime in here if I am wrong but I was under the impression that if you have jailbroken with Seasonpass, updates are disabled by default? Since using the jailbreak, I have never received any updates on my ATV2 unless I go out and get them myself manually.
Thanks for the response, I notice an update was out and was afraid of an auto update. I remember there was a feature that would let you turn off the auto update but Its not in settings anymore. thank you again.
This is pretty much correct, though it’s actually aTV Flash (black) which prevents updates from being installed.
