Hi… I’ve a 480p mp4 that I ripped from a dvd that Infuse wants me to upgrade to Pro to play.
This is the only file I’ve come across like this
How do I determine what is causing infuse to require pro? I’ll happily rerip the dvd, but i do t readily see info about how to ensure free feature will play the result.
Thx in advance for any guidance.
Use an app called mediainfo and post the results. Might be a special encoding if video or audio that is triggering it.
General
Complete name : /Volumes/Videos/Concerts/Rush - A_SHOW_OF_HANDS/A_SHOW_OF_HANDS.Title1.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/isom/avc1)
File size : 3.52 GiB
Duration : 1 h 29 min
Overall bit rate : 5 655 kb/s
Movie name : A_SHOW_OF_HANDS.Title1
Encoded date : UTC 2022-03-02 17:12:07
Tagged date : UTC 2022-03-02 17:37:09
Writing application : DVDFab 12.0.6.1
Cover : Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L3
Format settings : 1 Ref Frames
Format settings, CABAC : No
Format settings, Reference frames : 1 frame
Format settings, GOP : M=1, N=24
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Source duration : 1 h 29 min
Bit rate : 5 206 kb/s
Width : 632 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.573
Stream size : 3.24 GiB (92%)
Source stream size : 3.24 GiB (92%)
Writing library : x264 core 148
Encoding settings : cabac=0 / ref=1 / deblock=0:0:0 / analyse=0:0x111 / me=umh / subme=0 / psy=0 / mixed_ref=0 / me_range=12 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=8 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=24 / keyint_min=13 / scenecut=0 / intra_refresh=0 / rc_lookahead=20 / rc=cbr / mbtree=0 / bitrate=5206 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=5206 / vbv_bufsize=5206 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=0
Tagged date : UTC 2022-03-02 17:37:08
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Menus : 3
Codec configuration box : avcC
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 286 MiB (8%)
Title : English (ac3 5.1)
Language : English
Service kind : Complete Main
Default : Yes
Alternate group : 1
Menu
Format : Timed Text
Codec ID : text
Menu For : 1
Source duration : 5347042
Source frame count : 19
Source stream size : 447
Frame count : 19
Stream size : 447
00:00:00.000 : Chapter 1
00:06:57.350 : Chapter 2
00:13:28.674 : Chapter 3
00:18:11.690 : Chapter 4
00:23:49.027 : Chapter 5
00:28:54.666 : Chapter 6
00:33:25.336 : Chapter 7
00:38:36.681 : Chapter 8
00:43:36.013 : Chapter 9
00:49:33.337 : Chapter 10
00:59:12.348 : Chapter 11
01:02:46.996 : Chapter 12
01:08:20.329 : Chapter 13
01:13:24.333 : Chapter 14
01:16:54.009 : Chapter 15
01:18:57.332 : Chapter 16
01:24:24.025 : Chapter 17
01:27:18.333 : Chapter 18
01:29:01.669 : Chapter 19
It’s most likely the audio codec that requires a licensing fee from the developer.
I have to ask though, if you like the player have you thought about doing a subscription to the pro version? Then you don’t have to re-rip things and you’ll also be supporting the developer so even more good things can be added.
I’ve no issue purchasing software… I just want to have a better idea of how it works before I do so, and haven’t really had a chance to put this through its paces.
Generally surround sound is going to require pro and also if you want to airplay anything. Try finding something with just a stereo track and see if that works. I make travel friendly h264/h265 versions with aac stereo that doesn’t require pro
