How to delete Infuse downloads from iPad?
Hi team,
I like to keep my iPad loaded up with TV shows for going away etc, though I’ve noticed a real issue with deleting them once I’m done. I can delete from within the app, and the Infuse folder shows as empty on the device, but the memory is still all used up. The only fix that I can find is to delete the Infuse app completely and then re-install it, having to set it up again.
How do I delete the files and get the space back without reinstalling Infuse? It seems to be either impossible or unintuitive…
Thanks!
This post may help.
Perfect, thank you!
