In NitoTV, Network area, I added a Mount,and now after trying 3 times to mount , I now have 3 different Mounts, which I can’t figure out how to Delete
to start all over again. How do you start fresh, and delete those erroneous Mount setups?
OK, I used Cyberduck, and found mounts.plist . How to I refresh this to end up with a clean slate?
The mounts can be deleted through the view/edit settings menu. Highlight the mount in the nitoTV → Network menu, press the right arrow, and select ‘remove mount point’ from the bottom of the list.
