How to clear "watching" items?
I’d like to clear the “watching” bar/list. How can I do this?
Currently the way to do this is mark an item as watched.
A more flexible way to add/remove items from the Watching list will be available in an upcoming version.
If you want to completely remove it, you can disable it in settings.
Where do I disable in settings??
Settings> Up Next List
This was two years ago. When is this version coming up? I still do not find this new flexible way?
To remove an item from the watching list …
  • select the item
  • select Playlists button
  • untick Watching item in Up Next List
To add an item to the watching list, similar process but tick Watching item in Up Next list
I don’t think there is a option to easily clear the whole watching list.
