hi, is there away to add custom fanart to separate seasons instead of just one image for fanart which shows for all seasons, when I add 2 or more seasons I get the same fanart for all seasons I don’t want that.
Currently there is one one option for “Fanart” and that’s for the series.
You can create a Seasons poster using the instructions in the metadata users guide though.
