For Movies, folder.jpg works perfectly.
For TV series, I can’t seem to use folder.jpg to replace the Artwork fetched from TMDb
For example,
Tom and Jerry
- Tom and Jerry Season 1
- S01E01 xxxx.mp4
- S01E02 xxxx.mp4
- Tom and Jerry Season 2
- S02E01 xxxx.mp4
- S02E02 xxxx.mp4
- Tom and Jerry Season 3
- S03E01 xxxx.mp4
- S03E02 xxxx.mp4
Infuse is able to get medadata, group them into 3 Seasons, but the fetched posters for Season1/2/3 don’t look good…
I can’t find a way to use customized folder.jpg as Artwork of each Season, I placed folder.jpg into each Season folder, didn’t work, I renamed it to same as folder name like “Tom and Jerry Season 1.jpg”, didn’t work too.
The same happened to iOS Infuse, if I download all of these files into iPhone, they appear as 3 Seasons but again, how can I change the Artwork?
