How does one create a poll?
I seem to have forgotten or lost the feature I used to create my last one.
When you create a thread under the gear there should be a “Build Poll” option. :wink:
That’s what I thought but I’m not seeing it. :confused:
Can you scroll up on the dropdown?
Ha! That did it. How bizarre.
Weird that scroll bars only appear while you actually scroll, rather than to indicate the field is scrollable.
Also strange that when I went back to edit my original post, and clicked the wheel, no scrolling was necessary, as all options were shown.
Thanks!
