How does Infuse handle syncing?
What I mean by this is if I set up my Home Screen on my Apple TV, how do I know that when I open the app on my Mac or iPhone it’ll be the same layout and that those layouts don’t just overwrite what I did on the Apple TV? Is there a way to say “Hey, always follow whatever happens on the Apple TV.”?
Often times people prefer to have different layouts on different devices, so currently Infuse will keep Home Screen layouts in sync between like devices.
For example, a home screen you set up on Apple TV would sync to other Apple TVs.
Okay, this makes so much sense now. Thank you, James.
So what you’re saying is that it is the correct behaviour that my iPad’s layout doesn’t carry across to my Apple TV (the behaviour I’m seeing)? I can see the logic, though a way for true sync across all devices would be nice. I get maybe different layouts make sense, but why are my detail display settings and per-content metadata rules not syncing? I’m using the same Apple ID on my Apple TV as on my iPad. Really annoying to have to fix mismatches on both devices. iCloud Sync – Firecore Support Says this stuff should be syncing.
