How do I use iXpand Go with Infuse?
I recently got a 64gb iXpand Go, and I’ve been trying to make it show up in Infuse (7.5.9) on a iPad 8th gen (iPadOS 16.6). It doesn’t appear anywhere in the app, is there a trick to it or something?
Also, if it makes a difference, I did reformat the drive to exFat, rather than fat32.
Unfortunately, some newer rev iXpand devices will not be compatible with Infuse, as these include newer hardware/firmware versions and SanDisk has seemingly discontinued their 3rd party support program.
However, to get these to appear in Infuse you can link them by navigating to Infuse > Settings > Add Files > Add… > Add Local Folder.
