as many other, on my atv2 I have a suddenly not working lan and even after a restore the problem persist.
I cannot use the wireless because even without cable my atv2 says there is a network cable connected.
Anyone knows a way to disable the lan cable identification?
Without this mod these atv2s are completely unuseful.
Is there a command or a plist that can be modified to enable a “use always wlan”?
thanks
NoiZe
