How can I help folders load faster?
I’m hosting files on my Mac mini which is pretty old but I’m just seeing if there are any ways to speed up the loading of my movies/tv shows when I open my favorites folder on infuse tvOS and iOS. It takes usually from 5-30 seconds or so for the cover art to show up. I don’t have a huge library either. I had them on a Plex share on another computer and it did have a speed increase for loading. Anyone else figure out a way to make it faster loading? I’m hoping to get it to open instantly!
Hi :slight_smile:
Try to use the Library and create a shortcut on the main screen for “All Movies” etc…
Then the Movies/CoverView loads much faster than the Favorites-Folders! :slight_smile:
(you can hide the favorite from the main screen as well)
