How best to connect from cellular remotely?
Currently, I have an SFTP connection to a local computer hard drive folder.
Using local Wi-Fi on my phone I have access, however using ONLY iPhone cellular connection remotely the favorite folder - does not fail connection and seems to connect however the window is black without showing any content. (if I add local wifi - then it works and shows content)
Is there a proper procedure to be able to View content from cellular Remote connection (no wifi) on the iPhone?
Here’s a users guide that should get you started.
