Home Screen Layouts (Library Lists) Not Syncing Across Devices
iCloud 同步中主屏幕布局的同步,列表是否包含Plex、Emby等的项目列表?
Does iCloud sync include Plex/Emby library listings in Home Screen layouts?
  • Saved Home Screen layouts (Lists & Favorites)
    保存的主屏幕布局(列表 & 收藏夹)
iOS和macOS中均使用最新的TF版本8.1.7(5205), iOS和macOS上的 Infuse 主屏幕布局并没有同步(如下图)。
Both iOS and macOS are running the latest Infuse version 8.1.7 (5205), but the Home Screen layouts are not syncing between devices (see screenshots below).
这在新设备、重新安装 infuse 或者添加了新的媒体服务的情况,需要在多端上分别进行主屏幕的设置和排序,相当来说有一些繁琐。
This becomes particularly tedious when setting up new devices, reinstalling Infuse, or adding new media services, as the Home Screen customization needs to be done separately on each device.
印象中在较早的版本中,在ios进行Plex、Emby的项目列表设置、排序是会通过 iCloud 通道到mac OS 和 ATV 的主屏幕上的;这是否是一个Bug,还是我记忆的错误?
I recall that in earlier versions, the organization and sorting of Plex/Emby libraries on iOS would sync to macOS and Apple TV via iCloud. Is this a bug in the current version, or is my memory incorrect?
如果iCloud同步中的主屏幕布局不包含 Plex、Emby 项目布局的同步,希望可以增加项目布局的同步功能。以下是相似的反馈。
If the iCloud sync for the home screen layout does not include the arrangement of Plex and Emby items, we hope this feature can be added to sync the item layout as well. Below is similar feedback.
iCloud Sync / iCloud 同步
What is Synced 哪些设置会被同步
Free + Pro 免费版 + 专业版
  • Saved networks shares (address, username, password, etc…)
    保存的网络共享(地址、用户名、密码等)
  • Saved Favorites
    已保存收藏夹
    保存的主屏幕布局(列表 & 收藏夹)
  • General settings (iOS backups only)
    常规设置(仅限 iOS 备份)
  • Direct URLs added via ‘Add Files’ on iOS/macOS/visionOS
    通过 iOS/macOS/visionOS 上的"添加文件"添加直接URL
  • Manual metadata matches (corrections for mismatched titles)
    手动元数据匹配(纠正不匹配的标题)
  • File-specific playback settings (selected audio/subtitle track, zoom setting, etc…)
    文件特定的播放设置(选定的音频/字幕音轨、缩放设置等)
  • Downloaded subtitles
    已经下载的字幕
  • Custom playlists
    自定义播放列表
  • Custom collections
    定制系列
Pro Only 仅限专业版
  • Up Next list (in-progress and recently added items)
    最近播放列表(进行中和最近添加的项目)
  • Watched history
    播放记录
  • Playback position for in-progress items
    播放进度
  • Ratings
    评分
