High Frame Rate HDR content
Does Infuse 7 or 6 Pro play High Frame Rate HDR content for 4k content in 60fps 60Hz or only 24fps 60Hz???
Yes, if you play 60fps content it will be played in 60Hz on the screen.
If you’re using an Apple TV, you can enable the Match Content options and Infuse will automatically adjust the video output to match the actual video being played. This includes support for both integer and non-integer frame rates (EG 24.000Hz / 23.976Hz).
