Hiding menus?
I could have sworn that one of the features before I bought ATVFlash was the ability to choose while menus to hide on the bar. I can’t seem to figure out where to do that.  Also, I installed XBMC but would like to remove it now. There doesn’t seem to be a way to uninstall those.
Thanks!
Well, I just ended up restoring from Apple, re-jailbreaking, and re-installing ATV Flash. No biggie there. But I’d still like to hide unused menus. Anyone?
You can install Overflow (via nitoTV) which allows you to hide menus.
