help
my jailbroken atv2 went wrong and crashed i have since loaded season1 jailbreak.what do i do now.i no longer have xbmc.or cannot get anything free apart from podcasts.help would be appreciated.
Really sorry to hear your jailbreak got affected. Hopefully your firmware is on the correct version. Check your settings to make sure you’re on a compatible version and then try starting all the way from scratch:
