Hi all,
Need some help with setting up remote access. At the moment, I am attempting to ensure that I can use Infuse when not at home (e.g. at work, while traveling, etc.).
I currently use Infuse on 4 devices: Mac Studio (which has wired 2 external hard drives), which are the items I want to remotely access with Infuse), and a MacBook Pro, iPhone, and iPad.
The libraries are set up as follows:
- Studio - 3 local folders (film, television, “offloaded”) from the 2 hard drives
- The shared version of these folders are in my library, syncing those from iCloud on the other devices
- Other 3 - All point to those^ 3 folders using the smb share setup
While at home, I can access my files over the network with this setup, no problem.
I would like the MacBook Pro, iPhone, and iPad to be able to access the Mac Studio/hard drive shares remotely when off of my home Wi-Fi network, and to this end, have put them all in my Tailnet/Taildrive/etc using Tailscale. I can successfully access those files in Finder when off of my network on all of those devices when using Tailscale, in the same way as I would when accessing my shared files at home. If I am off of my home network and turn on Tailscale, and attempt to play these files in Infuse, it doesn’t work (which is as expected).
I have seen people using Jellyfin or Emby in addition to Tailscale (for this/similar purpose, i think?), but I would rather not use them, I prefer to only use Infuse, but if needed, can look into this.
As simply as I can surmise, my situation is this: I can connect to Tailscale to access the media files on my mac studio from anywhere on all of these 3 devices. I could play the video files in Finder/Files, etc, but I want to set up a way to access and play them in Infuse. I am unsure of how to do this, how can I make Infuse point to the Tailscale share?
My questions are:
- What should I point the libraries to on these 3 devices to ensure they go through Tailscale and can access my files off of my network?
- If I make them all point to the Tailscale IP of the mac studio, will this mess up my infuse library on there?
- I understand this may require Tailscale to be always on, but thats fine
- Should I be using the same server http url I use to connect my devices to Tailscale, the IP of the Mac studio I want to share files from, or something else?
Thanks in advance, all!!!
