Help with SSH ATV?
Hey guys, I have the latest firmware and latest apple core llc patch installed. I can’t ssh into my appletv, as I used to be able to do, I can’t figure it out!
My ip address is 192.168.0.1 so, I have been using that with fugu and in the username writing frontrow
but it won’t do anything…
any help?
I want to do this so I can get afp access again
Mo
Are you sure the Apple TV is 192.168.0.1? That is usually held for the router IP address. Go under Settings > General and it will show your Apple TV IP address.
Try some other SSH programs too like “Cyberduck”.
My Fugu got all fugued-up and Cyberduck did just fine.
Strange how some work sometimes and others work when earlier ones don’t.
And don’t ever forget: It’s a Hack!
