Hi, I’m a new user of Infuse having moved from Plex in many years.
I’m trying to understand how I can apply customer work to my TV library. I don’t tend to use library view very much as you can’t seem to set custom collection posters (for example if I have multiple TV shows in a custom collection I can’t set artwork for that collection. It just shows a tiling of the first four shows).
I use folder to navigate in many cases as you can set custom artwork at a folder level but I can’t figure out how to get it to work for TV shows. I followed the infuse guidance as below:
"TV Show Artwork
Overriding series/season artwork is available when episodes are organized into folders by season (Series Name/Season X/episodes.mkv).
E.G. Breaking Bad/Season 1/Breaking Bad S01E01.mkv
Usage details
Episode image
seriesname/season 1/episodefilename.jpg
Season poster
seriesname/season 1-poster.jpg
All Seasons poster
seriesname/season-all-poster.jpg
Series poster (available only while using Library)
seriesname/poster.png
Series fanart
seriesname/fanart.png
Series logo
seriesname/logo.png (or clearlogo.png)"
What then happens in folder navigation ‘view’ is that I end up having a folder for each season which is blank (no artwork) and then that has inside each individual season folder, the season with custom artwork recognised. I then have to go into that folder to get to the season which then opens into the library view. It isnt a deal breaker but is annoying you need to go into a folder with the season name to then go into the season itself.
Are there any other ways of doing this? I tried using local metadata but then you lose all the nice stuff like clear logos etc.
