Help with a file that struggles playing
This file stutters and eventually will get the spinning circle.
Thanks for your help.
Format                                   : Matroska
Format version                           : Version 2
File size                                : 4.54 GiB
Duration                                 : 44 min 55 s
Overall bit rate mode                    : Variable
Overall bit rate                         : 14.5 Mb/s
Movie name                               :
Encoded date                             : UTC 2022-12-11 16:44:38
Writing application                      : DVDFab 12.0.9.4
Writing library                          : libebml v1.4.2 + libmatroska v1.6.3
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 10.9 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.220
Stream size                              : 3.43 GiB (76%)
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : BT.2020
Mastering display luminance              : min: 0.0000 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 1001 cd/m2
Maximum Frame-Average Light Level        : 961 cd/m2
Audio
Format                                   : MLP FBA 16-ch
Format/Info                              : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name                          : Dolby TrueHD with Dolby Atmos
Codec ID                                 : A_TRUEHD
Bit rate mode                            : Variable
Bit rate                                 : 3 394 kb/s
Maximum bit rate                         : 6 108 kb/s
Channel(s)                               : 8 channels
Channel layout                           : L R C LFE Ls Rs Lb Rb
Sampling rate                            : 48.0 kHz
Frame rate                               : 1 200.000 FPS (40 SPF)
Compression mode                         : Lossless
Stream size                              : 1.06 GiB (23%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Number of dynamic objects                : 11
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
Text #1
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 42 min 0 s
Bit rate                                 : 2 915 b/s
Count of elements                        : 192
Stream size                              : 897 KiB (0%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Text #2
Format                                   : PGS
Duration                                 : 39 min 43 s
Bit rate                                 : 28.9 kb/s
Count of elements                        : 810
Stream size                              : 8.22 MiB (0%)
Language                                 : English
Default                                  : No
Forced                                   : No
Text #3
Format                                   : PGS
Duration                                 : 41 min 59 s
Bit rate                                 : 33.0 kb/s
Count of elements                        : 1030
Stream size                              : 9.90 MiB (0%)
Language                                 : English
Default                                  : No
Forced                                   : No
Menu
00:00:00.000                             : en:Chapter 01
00:11:35.027                             : en:Chapter 02
00:20:42.407                             : en:Chapter 03
00:30:51.975                             : en:Chapter 04
00:42:52.111                             : en:Chapter 05
What version number of Infuse and what device and device OS?
@NC_Bullseye
Infuse Pro 7.4.10 (4329)
Apple TV 16.3.2 (20K672)
Are you seeing this with other files or just this one?
If you’re able to send send in a sample video that is having issues we can look into this.
https://upload.firecore.com
@james,
Thanks. I just encoded the files and they play fine now.
what was the solution?
I’m guessing they just re-encoded the file because the first was glitchy?
Agree if there was a cause identified it would be nice to post it here so others who might have a similar issue can learn from it.
Yes, the file would play and stutter and then stop completely. I posted the media info in hopes the team could identify the issue, but in the mean time I re-encoded the files. I would have uploaded a sample, but I’m not entirely sure how to do that.
