koops
#1
Hi Guys
I updated my ATV2 yesterday to the latest firmware so I could get netflix in the UK
The tried to jailbreak and keep getting a 3194 error
The cable i have is good
After reading it look like its the host file
Im running Windows 7 so had to run notepad as administrator and open the hosts file and change te IP to 74.208.10.249 gs.apple.com reboot try agin
Still getting the error
tried umbrella and reboot
still getting the same error
So now im stuck and haave not found any other solutions to this
any idea what else i could try
thanks
koops
#2
Sorted reset the host file using
http://support.microsoft.com/kb/972034
reboot and then run seasonpass
scseo
#3
also encountered the same problem
What Frimware Version is the ATV 2 on?
If you are at 5.0 there is not jailbreak yet.
my firmware is 4.4.4 and i have the same problem…help!
